What goes in this parameter?
Let's say I made a temporary sphere following Create Temp Spherical Sheet Body
I had to use
ball.CreateTrimmedSheet4(new Curve[] { null }, true); // or ball.CreateTrimmedSheet4(new object[] { null }, true); // vv these don't work, I get runtime exceptions vv ball.CreateTrimmedSheet4(new object[] { }, true); ball.CreateTrimmedSheet4(new Curve[] { }, true); ball.CreateTrimmedSheet4(null, true); // especially this one
The docs say to insert a null between trimming loops, but if your surface is periodic, you can forego the Curves parameter. The example used an Empty. What does that mean in terms of C#? I'm not well acquainted with VBA, so I don't know what the C# equivalent of Empty is, and neither null nor an empty array seems to be the substitute.
Are there examples of using CreateTrimmedSheet4() for other shapes?
You need to use
Here is working example: Reconstruct Spherical Surface
