Macro to create DXF of each Configuration of sheet metal part
Question asked by Geoff Moss on Aug 16, 2018
I have a simple macro that takes an active part file, and checks if each body is sheet metal, and if so creates a DXF of it. I want to modify it to create a DXF of each configuration, after checking if that configuration is a sheet metal body.
Typical usage situation: SLDPRT with configuration named MASTER which is a multi-body sheet metal part. Then a series of configurations, each named according to the respective part number, each one using BODY-DELETE features to remove all but one sheet metal body.
I would like the macro to traverse each configuration, check if the resulting model is a sheet metal body, and if so export the flat pattern to DXF. Here is my code for doing so on a single-configuration multi-body part:
Dim featureMgr As SldWorks.FeatureManager
Dim feat As SldWorks.Feature
Dim sheetMetalFolder As SldWorks.sheetMetalFolder
Dim swConfigMan As IConfigurationManager
Dim swConfig As Configuration
Dim swObj As Object
Dim swBody As Body2
Dim nBendState As Long
Dim varBodies As Variant
Dim featArray As Variant
Dim i As Long, nCount As Long
Option Explicit
    Set swModel = swApp.ActiveDoc
    If Not swModel.GetType = swDocPART Then
        Debug.Print "Must be a part file; exiting..."
        Exit Sub
    Set swPart = swModel
    Set featureMgr = swModel.FeatureManager
    varBodies = swPart.GetBodies2(swBodyType_e.swSolidBody, True)
    For i = 0 To UBound(varBodies)
        Set swBody = varBodies(i)
        If (swBody.IsSheetMetal) Then
            Debug.Print "Sheet metal found!"
            Set sheetMetalFolder = featureMgr.GetSheetMetalFolder
            Set swConfig = swModel.GetActiveConfiguration
            Debug.Print "Configuration: " & swConfig.Name
        Else
'            Debug.Print "No sheet metal found..."
    Next i
