how to find arrowhead coordinate?
Thank you Nilesh but this link is use full for part document and i am working on drawing document but it's not help full for finding arrow head coordinate or not mention how to detect position of arrow head
Actually i have all ready find all annotation in drawing document but unable to find coordinate of individual annotation because i need to create bounding box for arrowhead
i was used : ThisAnn = DisplayDimension.GetAnnotation();
double[] pt =ThisAnn.GetPosition();
x = pt[0];
y = pt[1];
z= pt[2];
but its not sufficient for detecting arrow head coordinate or position
Have a look at the attached macro:
Option Explicit Sub main() Dim swApp As SldWorks.SldWorks Dim swModel As ModelDoc2 Dim swSelMgr As SelectionMgr Dim swSelData As SelectData Dim swDraw As DrawingDoc Dim swView As View Dim swAnn As Annotation Dim vLeaderPt As Variant Dim nbrLeaders As Long Dim nNumPts As Integer Dim i As Integer Dim j As Integer Dim k As Integer Set swApp = Application.SldWorks Set swModel = swApp.ActiveDoc Set swSelMgr = swModel.SelectionManager Set swSelData = swSelMgr.CreateSelectData Set swDraw = swModel Set swView = swDraw.GetFirstView Do While Not Nothing Is swView Set swAnn = swView.GetFirstAnnotation3 Do While Not swAnn Is Nothing Debug.Print " Annotation name: " & swAnn.GetName Debug.Print " Annotation type (enumerator numeric value): " & swAnn.GetType If True = swAnn.GetLeader Then nbrLeaders = swAnn.GetLeaderCount For i = 0 To swAnn.GetLeaderCount - 1 If True = swAnn.GetBentLeader Then nNumPts = 3 Else nNumPts = 2 End If swAnn.Select3 False, swSelData vLeaderPt = swAnn.GetLeaderPointsAtIndex(i) If Not IsEmpty(vLeaderPt) Then Dim leaderPt() As Double ReDim leaderPt(nNumPts) As Double leaderPt = vLeaderPt k = 0 For j = 0 To UBound(leaderPt) Debug.Print " Pt[" & k & "] x,y,z coordinates:" Debug.Print " " & Str(leaderPt(j) * 1000) & ", " & Str(leaderPt(j + 1) * 1000) & Str(leaderPt(j + 2) * 1000) j = j + 2 k = k + 1 Next j End If Next i End If Set swAnn = swAnn.GetNext3 Loop Set swView = swView.GetNextView Loop End Sub
Have you looked at the example: 2018 SOLIDWORKS API Help - Get Display Dimensions, Gtols, and Surface-Finish Symbols Example (VBA)
