Is there a way to reuse or reassign a project number that was automatically created in PDM? Let's say I thought that I would need 5 projects for a job, but only needed three. Can two of the projects be deleted and have the auto-generated numbers put back in queue?
in the PDM admin tool you need to find the serial number that is being used and set the next number
the serial number will just assign the next counter value and then increment that field
you can set the next counter value to whatever you want
i don't think that you can 'fill in gaps' in your numbering sequence but can roll back the most recent number
