I'm working with the PDMW API to create a custom client app
and I have a question about custom properties. These properties are
specified in the Vault Admin Tool and should be applied to all
documents in the vault regardless of document type.
Is it the Vault's responsibility to add these properties to the file or the clients?
It seems when I check something in via the API (using the CheckIn method provided) that only the default 6 properties get added to the document. Is this the correct behavior or am I doing something wrong? Thanks.
