There is a fully defined sketch. Deleting a dimension in that sketch making the sketch over defined one. What will be the reason for that?
I meet the same with complex 2d sketches and nearly simple 3D sketches even without any equation driven curves and other equations.
Please, read this article till the end to be more famililar with the math problems of geometric constraints solving
https://www.3dcadworld.com/cheetah-creo-2d-geometric-constraint-solvers/
I`m sure you`ll get answer to your question there.
Hi Maha,
Are you able to post pictures of before and after the dimension delete?
Dave.
