drawing document will not save after macro
Question asked by Robert Caste on Aug 10, 2018
Latest reply on Aug 10, 2018 by Deepak Gupta
This opens a drawing file in my template, puts views on second page, activates the first page again and exits, but will not save in the output folder as specified by the open assembly model. I’ve tried setting to dirty and running in #task and still no luck. I’ve also tried using actual parameters for the save method and recording a save macro on the drawing document, then running that macro with the drawing and it still didn’t save.
Option Explicit
Dim Part As Object
Dim vConfs As Variant
Dim i As Integer
Const sDrTemplate As String = "\\zserver\Sharepoint\Hamel\templates\Zephyr\ZEP B-FAB APUCOLUMNWELD.drwdot"
Dim longstatus As String
Dim longwarnings As Long
Dim vSheetName, vModelName
Dim sOutputFolder As String
Dim swFeatMgr As SldWorks.FeatureManager
Dim swView As SldWorks.View
Dim swBomAnn As BomTableAnnotation
Dim swBomFeat As SldWorks.BomFeature
Dim AnchorType As Long
Dim BomType As Long
Dim Configuration As String
Dim TableTemplate As String
Dim Names As Variant
Dim Visible As Variant
Dim boolstatus As Boolean
Dim swSheet As SldWorks.Sheet
Sub Main()
    Set swModel = swApp.ActiveDoc
    sOutputFolder = Left(swModel.GetPathName(), Len(swModel.GetPathName()) - Len(swModel.GetTitle()))
' New Document
Dim swSheetWidth As Double
swSheetWidth = 0.4318
Dim swSheetHeight As Double
swSheetHeight = 0.2794
Set swDraw = swApp.NewDocument(sDrTemplate, 0, 0, 0)
Dim swDrawing As DrawingDoc
Dim swDrawModel As SldWorks.ModelDoc2
Set swDrawModel = swDraw
swDraw.InsertModelInPredefinedView swModel.GetPathName()
    Set swFeatMgr = swModel.FeatureManager
    Set swDraw = swDraw
    Set swSheet = swDraw.GetCurrentSheet
  'Visit each sheet
  vSheetName = swDraw.GetSheetNames
  For i = 0 To UBound(vSheetName)
    'Activate and access
    swDraw.ActivateSheet vSheetName(i)
    Set swSheet = swDraw.Sheet(vSheetName(i))
    If swSheet.IsLoaded Then
      'Okay
    Else
      If MsgBox(vSheetName(i) & " is not loaded.", vbOKCancel + vbDefaultButton2) = vbCancel Then Exit Sub
    'Visit all views
    Set swView = swDraw.GetFirstView
    While Not swView Is Nothing
      'Debug.Print "    " & swView.GetName2 & " [" & swView.Type & "]"
      Select Case swView.Type
        Case swDrawingViewTypes_e.swDrawingNamedView
          If IsEmpty(vModelName) Then
            'Get the model loaded in this view
            vModelName = swView.GetReferencedModelName
          Else
            'Set the model in this view
            swDraw.InsertModelInPredefinedView vModelName
          'Make the sketches visible
          'swView.ResetSketchVisibility
      End Select
      Set swView = swView.GetNextView
    Wend
    'swModel.swSaveAsOptions_Silent , Empty, Empty
  Next
  'Back to first view
  swDraw.ActivateSheet vSheetName(0)
  'Force a rebuild!
swModel.EditRebuild3
    swModel.Save3 swSaveAsOptions_Silent, Empty, Empty
    swApp.QuitDoc swModel.GetTitle
End sub
