When adding a note to the drawing template so it is easily editable it is fine for the first sheet but then does not show up when adding a new sheet to the document. If a note is not in sheet format then it does not show up when creating new sheets. Specifically, I have a note with leaders that I would like to easily and quickly move around a drawing but my drawing has multiple sheets where I would like this note to appear. I could place it on the sheet format and it will appear on new sheets but then extra steps must be taken to edit the leaders and note. I was wondering if there is a possible way to accomplish this?
I'm almost certain you can't get the workflow you want, but this might work for you:
3. Save as...Drawing Template.
That won't insert it automatically in new sheets, but you can activate the Note command and select it from the drop-down, and it's simpler than copying and pasting. I have a dozen or so commonly used notes saved there (many of which are linked to custom properties).
