I'm trying to create an interactive menu where the user clicks the image of a build step to go to that step. I have managed to do this fine. However, when I update the images files, the ones in the composer view do not update. On top of this, going in and manually changing them does not work as the images have the same file names and the software must have them stored somewhere. Even if I change the path to a completely different image and then change it back to the right file, it still pops up with the old image. Is there any way to update the images?
Ben
Hi Ben,
The software stores the images inside the .smg file. If you try to unzip the .smg file, then you can see the image file. That's the reason you can't see updated image automatically in your .smg file. The only way is to map the path to the new image. Hope this helps.
Sandip
