I need to cover this area with a plate so I can mount things to it. Any suggestions?
So, what I did was 3d sketch over the higlighted areas and then used boundary surface to construct this surface. This is pretty much what i was looking for ascetically, but now I need to convert this surface to a solid and also make it a separate piece so I can cut holes into it to mount a heat exchanger.
NOTE: Boundaries must be different sketches.
Edit 1: Once you create the surface use the thicken tool to convert into a solid.
