I would like to create the same feature using sheet metal. I used to make the model using features instead, by creating one feature and rotating it in the middle axis. Can someone tell me how can this be done using sheet metal instead?
If I'm understanding you correctly, then your first picture would be your sheetmetal base flange extrusion.
You would then put the bends in with "sketched bend" feature.
I would just create one slice of the pie, create the sheetmetal base flange and two bends, then revolve the pattern and add the cut.
