I have been trying to use this bit of code to automate my drawing process:
' Preconditions:
' 1. Open public_documents\samples\tutorial\advdrawings\blade shaft.sldasm.
' 2. Click File > Make Drawing from Assembly > OK.
' 3. Click a blank area of the FeatureManager design tree.
' Postconditions:
' 1. Drops the Current, Isometric, and Front views onto
' the drawing sheet.
' 2. Examine the drawing and Immediate window.
Option Explicit
Dim swDrawing As SldWorks.DrawingDoc
Dim swFeature As SldWorks.Feature
Dim swSubFeature As SldWorks.Feature
Dim swSheet As SldWorks.Sheet
Dim swView As SldWorks.View
Dim bFound As Boolean
Dim vViewNames As Variant
Dim vViewName As Variant
Dim strViewName As String
Dim lNumViews As Long
Dim dSheetScale As Double
Dim vSheetProperties As Variant
Dim nPaperSize As swDwgPaperSizes_e
Dim dWidth As Double
Dim dHeight As Double
Set swModel = swApp.ActiveDoc
Set swDrawing = swModel
' Get current sheet
Set swSheet = swDrawing.GetCurrentSheet
vSheetProperties = swSheet.GetProperties
dSheetScale = vSheetProperties(2) / vSheetProperties(3)
nPaperSize = swSheet.GetSize(dWidth, dHeight)
Debug.Print "Sheet scale = " & dSheetScale
Debug.Print "Sheet width = " & dWidth
Debug.Print "Sheet height = " & dHeight
lNumViews = 0
vViewNames = swDrawing.GetDrawingPaletteViewNames
If (Not (IsEmpty(vViewNames))) Then
lNumViews = (UBound(vViewNames) - LBound(vViewNames) + 1)
Debug.Print "Number of views on palette = " & lNumViews
For Each vViewName In vViewNames
strViewName = vViewName
Debug.Print strViewName
If (strViewName = "*Current") Then
Set swView = swDrawing.DropDrawingViewFromPalette2(strViewName, dWidth / 5#, dHeight / 5#, 0#)
Debug.Print " Dropped => " & swView.Name
If (strViewName = "*Isometric") Then
Set swView = swDrawing.DropDrawingViewFromPalette2(strViewName, dWidth / 3#, dHeight / 2#, 0#)
If (strViewName = "*Front") Then
Set swView = swDrawing.DropDrawingViewFromPalette2(strViewName, dWidth / 4#, dHeight / 3#, 0#)
Next vViewName
This bit of code works great, if you make drawing from part/assembly.
My workplace's process is to have a single drawing file with multiple sheets with each assembly and child component that has any extra operations on it other than a straight cut. This means that if I use the above code per each sheet on the drawing, I can only put that model on those sheets because the "DropDrawingViewFromPalette2" only chooses the model that the drawing was created from.
Another note is that the above code does not work if you open a new drawing, then open the model to place in the drawing, and then run the code.
Is this possible to do? I have already made a macro to create a drawing and add the correct amount of sheets/ names based on sub assemblies/ parts.
Ian
EDIT:
I found that using predefined views works: swDraw.InsertModelInPredefinedView swCurModel.GetPathName(). I just don't know if there is a way to add predefined views to a new sheet, or add them to the sheet format. My current plan is to copy a "Source Sheet" and paste it over and over until I have all the sheets are there that I need. At the end of the macro I will delete it.
