eDrawings API via Excel
Question asked by Farzad Sidhva on Aug 9, 2018
I am attempting to use the edrawings VBA api via excel. I have downloaded the edrawings SDK and it seems as though the api only runs through a user form. I have made a few vba macros for solidworks via excel but unlike solidworks there is very limited documentation. I simply want to make a connection to the API, after which I should be able to take it from there.
For right now I would simply like to open up a solidworks drawing in edrawings via excel. So something like the following:
Sub OpenDrawing()
Dim xlBook As Workbook
Dim xlsheet As Worksheet
Dim eDraw As New EModelViewControl
Dim FilePath As String
Set xlBook = ActiveWorkbook
Set xlsheet = xlBook.Sheets(1)
FilePath
= Range("B1").Value
eDraw
.OpenDoc FilePath, False, False, True, ""
As an example, Range B1 is the following "C:\ _EngVault\000S\090\090-40400-01.SLDDRW". I have activated the EModelView2018 Type Library and running edrawings 2018. Again, once I can figure out how to connect to the program I should be good but I am unable to make it that far.
Also, do I need a user form for this or did I misunderstand?
Thank you in advance,
Farzad
