RCRobert Caste09/08/2018
I’m using this macro to edit my custom properties for older files. I’ve looked into task manager and want to use this if possible, but not sure how to edit my code so that it’ll open the file from a directory, run the macro, save and close.
Can anyone help me with adding to this macro? I’ve looked at a few blog posts and help files but I can’t get anything that I add in to work with this.
Option Explicit
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim vCustPropNames As Variant
Dim vCustPropTypes As Variant
Dim vCustPropVals As Variant
Dim colCurrent As New Collection
Dim colSkip As New Collection
Dim colMain As New Collection
Dim bSkip As Boolean
Dim bDefaultDataType As BooleanP
Sub Main()
Dim CustProp As CustProp
Dim curCustProp As CustProp
Dim i As Integer
'Clean up the collections.
Set colCurrent = Nothing
Set colSkip = Nothing
Set colMain = Nothing
Set swModel = swApp.ActiveDoc
Set swCustPropMgr = swModel.Extension.CustomPropertyManager(Empty)
swCustPropMgr.Delete "REVISION"
If swModel Is Nothing Then Exit Sub 'Exit macro since no document is open.
swCustPropMgr.GetAll vCustPropNames, vCustPropTypes, vCustPropVals
MsgBox " Custom Property data updated."
If Not IsEmpty(vCustPropNames) Then
    For i = 0 To UBound(vCustPropNames)
        Set CustProp = New CustProp
        CustProp.cpName = vCustPropNames(i)
        CustProp.cpType = vCustPropTypes(i)
        CustProp.cpValue = vCustPropVals(i)
        colCurrent.Add CustProp
    Next
AddMainCustProps 'Add all "main" custom properties to collection colMain with method AddMainCustProps.
bDefaultDataType = False
Do While colCurrent.Count <> 0
    For i = 1 To colMain.Count
        Set CustProp = colMain.Item(i)
        Set curCustProp = colCurrent.Item(1)
        If CustProp.cpName = curCustProp.cpName Then
            CustProp.cpValue = curCustProp.cpValue
            If bDefaultDataType = False Then
                CustProp.cpType = curCustProp.cpType
            colCurrent.Remove 1
            bSkip = False
            If colCurrent.Count = 0 Then Exit For
        Else
            bSkip = True 'bSkip = True If the custom property was NOT in the colMain collection.
    Next
    If bSkip = True Then
        colSkip.Add colCurrent.Item(1)
        colCurrent.Remove 1
Loop
        swCustPropMgr.Delete vCustPropNames(i)
    Next i
For Each CustProp In colMain
    swCustPropMgr.Add2 CustProp.cpName, CustProp.cpType, CustProp.cpValue
Next
For Each CustProp In colSkip
Next
Sub AddMainCustProps()
  AddCustProp "ASSEMBLY", swCustomInfoType_e.swCustomInfoText, ""
  AddCustProp "DESCRIPTION", swCustomInfoType_e.swCustomInfoText, ""
  AddCustProp "PART NO.", swCustomInfoType_e.swCustomInfoText, "$PRP:""SW-File Name"""
  AddCustProp "MATERIAL", swCustomInfoType_e.swCustomInfoText, """SW-Material@" & Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1) & """"
  AddCustProp "COLOR", swCustomInfoType_e.swCustomInfoText, ""
  AddCustProp "VENDOR", swCustomInfoType_e.swCustomInfoText, ""
  AddCustProp "VENDOR PART NO.", swCustomInfoType_e.swCustomInfoText, ""
  AddCustProp "WEIGHT", swCustomInfoType_e.swCustomInfoText, """SW-Mass@" & Mid(swModel.GetPathName, InStrRev(swModel.GetPathName, "\") + 1) & """"
  AddCustProp "REVISION", swCustomInfoType_e.swCustomInfoText, ""
  AddCustProp "DRAWN", swCustomInfoType_e.swCustomInfoText, "GH"
  AddCustProp "DRAWN DATE", swCustomInfoType_e.swCustomInfoText, "--/--/2018"
  AddCustProp "UNIT", swCustomInfoType_e.swCustomInfoText, "EA"
  AddCustProp "SOURCE", swCustomInfoType_e.swCustomInfoText, "M(MS),F(MJ),J(PJ),P(PS)"
  AddCustProp "SORTCODE", swCustomInfoType_e.swCustomInfoText, "SPL001"
  AddCustProp "ProdLine", swCustomInfoType_e.swCustomInfoText, "FC"
  AddCustProp "ROUTER", swCustomInfoType_e.swCustomInfoText, ""
  AddCustProp "COMMENT", swCustomInfoType_e.swCustomInfoText, ""
  AddCustProp "TOLLERANCE", swCustomInfoType_e.swCustomInfoText, "0.060"
Sub AddCustProp(cpName As String, cpType As Long, cpValue As Variant)
    CustProp.cpName = cpName
    CustProp.cpType = cpType
    CustProp.cpValue = cpValue
    colMain.Add CustProp
