Hi
Dimension and Hatches in Drawing Documents are red. I create new layer with Black color and set dimensions to it but no change occurred. Also changing system option color setting is unusable. Please help!
Hi
Hi Khalil,
If you have set the layers/colours up after the dimensions have been placed double check that the dimensions are on the layer. you can do this by selecting a dimension then checking its layer in the taskbar.
If the dimensions are on the correct layer but not displaying correctly it may be possible that they have been overset by the line colour command.
In future you can define the default layers in your document properties for each dimensions/note type and use this as your drawing template.
Go to line color and check default.
