Dim BOM As IEdmBomView3
Set BOM = eFile.GetComputedBOM("Standard Roll Up BOM", -1, ConfigName, EdmBomFlag.EdmBf_ShowSelected)
' Call BOM.SaveToCSV("c:\temp\guy.txt", True)
'----------------------------FILE.CREATE("C:\TEMP\BOM.TXT")
Dim fso As New FileSystemObject
Dim sw As TextStream
Set sw = fso.CreateTextFile("c:\temp\" & AssyName & ".txt")
'-----------------------------GET COLUMN HEADERS
Dim columns() As EdmBomColumn
BOM.GetColumns columns
Dim header As String
header = "LEVEL" & vbTab
Dim column As EdmBomColumn
For i = 0 To UBound(columns)
header = header & columns(i).mbsCaption & vbTab
Next
sw.writeline (header)
' -----------------------------Bom.READ EACH BOM ROW
Dim varVal As String
Dim rows() As Variant
Dim row As IEdmBomCell
Dim rowstring As String
Call BOM.GetRows(rows)
For p = 0 To UBound(rows)
Set row = rows(p)
rowstring = row.GetTreeLevel & vbTab
varVal = ""
column = columns(i)
Call row.GetVar(column.mlColumnID, column.meType, varVal, Nothing, "", True) <= varval never returns a value even though columns are being incremented, see above image showing variable watches.
rowstring = rowstring & varVal & vbTab
Debug.Print rowstring
Next
'-----------------------------WRITE THE ROW TO THE FILE
sw.writeline (rowstring)
Next
sw.Close
For both of your questions...
Try Set row = rows(i) after For i = 0 To Ubound(rows) for first loop only.
For second loop you may need to try Set column = columns (p)
Consider this:
Dim row As EdmBomCell
BOM.GetRows rows
For i = 0 To UBound(rows)
Set row = rows(i)
rowString = row.GetTreeLevel & vbTab
Debug.Print rowString
varVal = ""
For p = 0 To UBound(columns)
Set column = columns(p)
RetVal = row.GetVar(column.mlColumnID, column.meType, varVal, Nothing, "", True) <== . FAILS HERE AT RUNTIME WITH EXPECTED FUNCTION OR VARIABLE
If (varVal) <> "" Then varVal = ""
rowString = rowString & varVal & vbTab
Next
sw.writeline (rowString)
Next
