I am new to Solidworks API. Tried to write a code to do Sweep function using a 3D line Sketch and circle as path and profile. Full code has been given below. i am getting till before last command line to create swept feature. Circle and line are created and in the selected position when i am getting run time error '438' - Object doesnt Support this property or method. i dont understand the parameters passed to the Swept feature. ALso please give explaination about the parameters passed to the different Swept feature.
Option Explicit
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swSketchManager As SldWorks.SketchManager
Dim swSketchSegment As SldWorks.SketchSegment
Dim swSketch As SldWorks.Sketch
Dim status As Boolean
Dim myFeature As SldWorks.FeatureManager
Dim swSketchMgr As SldWorks.SketchManager
Dim boolstatus As Boolean
Set swModel = swApp.NewDocument("C:\ProgramData\SolidWorks\SolidWorks 2015\templates\Part.prtdot", 0, 0, 0)
Set swSketchManager = swModel.SketchManager
swSketchManager.Insert3DSketch True
Set swSketchSegment = swSketchManager.CreateLine(0, 0, 0#, 1, 0, 0#)
Set swSketch = swSketchManager.ActiveSketch
swModel.ClearSelection2 True
swSketchManager.InsertSketch True
swModel.ActivateSelectedFeature
Set swModelDocExt = swModel.Extension
status = swModelDocExt.SelectByID2("Right Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
Set swSketchSegment = swSketchManager.CreateCircle(0, 0, 0#, 0.005, 0, 0#)
boolstatus = swModelDocExt.SelectByID2("Sketch1", "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
boolstatus = swModelDocExt.SelectByID2("3DSketch1", "SKETCH", 0, 0, 0, True, 0, Nothing, 0)
Set myFeature = swModel.FeatureManager.InsertProtrusionSwept3(False, False, 0, False, False, 1, 1, False, 0, 0, 0, 0, True, True, True, 0, True, True, True, False)
Hello
The documentation on this page should tell you everything that you need to know. Please note the text at the bottom in the Remarks section noting which items to select with certain marks so the sweep function knows what selection to use for which argument.
2017 SOLIDWORKS API Help - InsertProtrusionSwept4 Method (IFeatureManager)
Edit:
I should also note that without your part attached to your post to use as a reference, it will be tough to troubleshoot this in my opinion.
How can I attach a file to a forum post?
