2 Replies Latest reply on Aug 7, 2018 12:53 PM by Tim Webb
    in api, how to cancel user change state request?
    Win Lai
      I need to do some checking when user change state, and I write some code in EdmCmdType.EdmCmd_PreState session, now, when the checking fails, how can I cancel the user change state request? does api support it? Please help, thanks a lot.
      Best regards,
      Andrew
        • Re: in api, how to cancel user change state request?
          Tim Webb
          Hi Win,
          Here's some code for you. It's a complete vb.net add-in that will block the transition if the "part number" is blank. Let me know if it works for you.
          Tim CEPA
          Believe in The Q!
          Get PDM answers now on our Live Chat!
          '===========================code below=========================
          Imports EdmLib
          Public Class BlockTransition
              Implements IEdmAddIn5
              Public Sub GetAddInInfo(ByRef poInfo As EdmLib.EdmAddInInfo, ByVal poVault As EdmLib.IEdmVault5, ByVal poCmdMgr As EdmLib.IEdmCmdMgr5) Implements EdmLib.IEdmAddIn5.GetAddInInfo
                  'Just some information for the Administrate Add-ins dialog box
                  poInfo.mbsAddInName = "BlockTransition"
                  poInfo.mbsCompany = "equivaQ Software, LLC."
                  poInfo.mbsDescription = "Blocks a transition if certain variables on the datacard are empty."
                  poInfo.mlAddInVersion = 1
                  poInfo.mlRequiredVersionMajor = 13
                  poInfo.mlRequiredVersionMinor = 0
                  poCmdMgr.AddHook(EdmCmdType.EdmCmd_PreState)
              Public Sub OnCmd(ByRef poCmd As EdmLib.EdmCmd, ByRef ppoData As System.Array) Implements EdmLib.IEdmAddIn5.OnCmd
                  Try
                      Dim variablename As String = "Part Number"
                      If poCmd.meCmdType = EdmCmdType.EdmCmd_PreState Then
                          Dim vault As IEdmVault12 = Nothing
                          Dim file As IEdmFile5 = Nothing
                          Dim folder As IEdmFolder5 = Nothing
                          Dim Ctr As Integer = 0
                          vault = DirectCast(poCmd.mpoVault, IEdmVault12)
                          For Ctr = 0 To UBound(ppoData)
                              file = vault.GetObject(EdmObjectType.EdmObject_File, ppoData(Ctr).mlObjectID1)
                              folder = vault.GetObject(EdmObjectType.EdmObject_Folder, ppoData(Ctr).mlObjectID2)
                              Dim vars As IEdmEnumeratorVariable10 = file.GetEnumeratorVariable
                              Dim ConfigNames As IEdmStrLst5 = DirectCast(ppoData(0), EdmCmdData).mpoExtra
                              Dim Config As String
                              If IsConfigInList(ConfigNames, "@") Then
                                  Config = "@"
                              Else
                                  Config = ""
                              Dim varvalue As Object = Nothing
                              If vars.GetVar2(variablename, Config, folder.ID, varvalue) Then
                                  If varvalue.ToString.Length = 0 Then
                                      poCmd.mbCancel = True
                                      MsgBox("Please make sure the '" & variablename & "' field is completed before transitioning.", MsgBoxStyle.Exclamation, "Incomplete card values")
                                      Exit Sub
                          Next Ctr
                  Catch ex As Runtime.InteropServices.COMException
                      MsgBox("HRESULT = 0x" + ex.ErrorCode.ToString("X") + vbCrLf + ex.Message)
                  Catch ex As Exception
                      MsgBox(ex.Message)
                  End Try
              Private Function IsConfigInList(ByVal ConfigNames As IEdmStrLst5, ByVal ConfigName As String) As Boolean
                  IsConfigInList = False
                  Try
                      Dim CurConfig As String
                      Dim Pos As IEdmPos5 = ConfigNames.GetHeadPosition()
                      While Not Pos.IsNull
                          CurConfig = ConfigNames.GetNext(Pos)
                          If CurConfig = ConfigName Then
                              IsConfigInList = True
                              Exit While
                      End While
                      Return IsConfigInList
                      Return False
                      MsgBox(ex.Message)
                      Return False
                  End Try
              End Function
          End Class
