It is Direction of Pull is going to decide whether draft is inward or outward. What is the meaning of arrow showing at Parting Line?
Ahh....that arrow is referring to the surface that you want drafted. If you notice...each of those edges has 2 surfaces attached to it. The little yellow arrow (I think) is telling you which surface you will be adding draft to (as it is possible to add draft to the other surface instead).
