Hi everyone,
We are about 50 people using Solidworks and EPDM. We are facing some problems about the implementation but the one that worries me more is problem moving the files.
Context:
We make asemblies with a lot of subassemblies with parts.
The parts are located in C:\PDM\........\Project01\PartStudies, when it fits with the assembly and it is OK, we move it to C:\PDM\PARTS.
During this process several people could have opened the assembly (while the part were in the original folder).
The issue is that when other users open the assembly once the part has been moved it appears supressed in Solidworks...The location in PDM is OK (C:\PDM\PARTS) but when I look the properties of the part inside the SolidWorks, it tries to find the file in the original location (C:\PDM\........\Project01\PartStudies)
¿Any idea?
Thank you!
SolidWorks PDM Standart is probable?
And if it is possible to describe process of relocation of files in more detail.
Files move manually? / automatically?
CheckIn, Workflow, Revizions is used?...
What settings at users / groups?
As I understood - users can work parallely. At the same time any of them can move files.
At this moment files of CheckIn?
After that other users perhaps will need to update local Cash and to receive the latests version (possibly manually).
There is an opportunity to set up Cash - it is possible to specify the necessary folders.
It is possible to update referenses manually.
Still there are settings of external references in Administration PDM and SolidWorks (what there settings?)
Toolbox is used? How it is set up? locally or in PDM?
Probably more initial information will not prevent.
