4 Replies Latest reply on Aug 6, 2018 6:13 AM by Learn Help
    How make a constraints between two parts
    Learn Help
      hello,
      i tried to add part into assembly parts and assembled it with it, so , i found how to add part , but, i had same problem when i tried to assembled it.
      this is my algorithm :
         swModel.ClearSelection2(True)
              swDocExt = swModel.Extension()
              MateName = "Concentric520" + strCompName
              FirstSelection = "Point1@Origin@" + strCompName & "@" + AssemblyName
              SecondSelection = "Point1@Origin@" + AssemblyName
              boolstat = swDocExt.SelectByID2(FirstSelection, "CONCENTRIC", 0, 0, 0, True, 1, Nothing, swSelectOption_e.swSelectOptionDefault)
              boolstat = swDocExt.SelectByID2(SecondSelection, "CONCENTRIC", 0, 0, 0, True, 1, Nothing, swSelectOption_e.swSelectOptionDefault)
              matefeature = swAssemblyDoc.AddMate3(swMateType_e.swMateCONCENTRIC, swMateAlign_e.swMateAlignALIGNED, False, 0, 0, 0, 0, 0, 0, 0, 0, False, mateError)
      when i run it, it works without error but the part isn't assembled.
      i tried to show the mateError  :  MsgBox(mateError) , it gives me : 4 as a result.
      Can you help me please, and thanks.
        • Re: How make a constraints between two parts
          Nilesh Patel
          If you want to select origin of the main assembly document then replace ""Point1@Origin@" + AssemblyName" with '"Point1@Origin" only in the following line.
          Replace "CONCENTRIC" with "EXTSKETCHPOINT" in following two lines.
          See if these changes works.
          Regards,
          Nilesh
              Learn Help
              hello, i do those modifications, but, i got the same response, nothing change
                  Nilesh Patel
                  Could you attach your assembly (if it is not too large) and the macro?
                      Learn Help
                      i can't, the size of my assembly is to high. but about the algorithm, i found other guys who use Point1@Origine@ with e.
                      my goal is to assemble the origin of  part with the assembly, or assemblr the axis of hte part with the assembly
                      i made same change  :
                      Code#
                              MateName = "Concentric52" + strCompName
                              FirstSelection = "Point1@Origine" + strCompName & "@" + AssemblyName
                              SecondSelection = "Point1@Origine" + AssemblyName
                              boolstat = swDocExt.SelectByID2(FirstSelection, "EXTSKETCHPOINT", 0, 0, 0, True, 1, Nothing, 0)
                              boolstat = swDocExt.SelectByID2(SecondSelection, "EXTSKETCHPOINT", 0, 0, 0, True, 1, Nothing, 0)
                              ' Add the mate
                              matefeature = swAssemblyDoc.AddMate3(swMateType_e.swMateCOORDINATE, 0, False, 0, 0, 0, 0, 0, 0, 0, 0, False, mateError)
                              If matefeature Is Nothing Then
                                  MsgBox(" mate failed! ")
                              swAssemblyDoc.EditRebuild3
                              swModel.ViewZoomtofit2()
                      I'm getting crazy about it...hope you'll find a solution!
