I scaled down a part (using SolidWorks Scale Feature) imported from SketchUp b/c it was ~1000x the size it should be. The modelling environment, however, remains to be huge. Zoom to fit does not work.
This makes it impossible to rotate the part. Drawing Files are also tough to create because the part will show up as tiny (even after using the Custom Scale in Drawing View).
Thanks!
Here's your issue:
The surfaces are 4674 in away from the origin. And Solidworks is including the origin in the zoom all.
The issue is your scale command:
You have 3 scales, and you scaled them all around the centroid. Which means that they stayed in their relative position, but got smaller.
If you delete the 2nd and 3rd scale and then modify the 1st scale to include all bodies, and then scale about the origin instead...you get a better result:
