DFDustin Fu30/07/2018
I installed SolidWorks license manager in May 2018 and it served license ever since.  However, I noticed it stop serving license yesterday with the following errors.  What do I need to do to correct this problem?  Thanks.
15:34:00 (lmgrd) Server's System Date and Time: Sun Jul 29 2018 15:34:00 Central Daylight Time
15:34:00 (lmgrd) pid 1896
15:34:00 (lmgrd) SLOG: Summary LOG statistics is enabled.
15:34:00 (lmgrd) Done rereading
15:34:00 (lmgrd) FlexNet Licensing (v11.13.1.4 build 179569 i86_n3) started on oitlm9 (IBM PC) (7/29/2018)
15:34:00 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
15:34:00 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
15:34:00 (lmgrd) License file(s): D:\SOLIDWORKS SolidNetWork License Manager\licenses\sw_d.lic
15:34:00 (lmgrd) lmgrd tcp-port 25734
15:34:00 (lmgrd) (@lmgrd-SLOG@) ===============================================
15:34:00 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
15:34:00 (lmgrd) (@lmgrd-SLOG@) Start-Date: Sun Jul 29 2018 15:34:00 Central Daylight Time
15:34:00 (lmgrd) (@lmgrd-SLOG@) PID: 1896
15:34:00 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.4 build 179569 i86_n3 ( build 179569 (ipv6))
15:34:00 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
15:34:00 (lmgrd) (@lmgrd-SLOG@) Listening port: 25734
15:34:00 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
15:34:00 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: Yes
15:34:00 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
15:34:00 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c D:\SOLIDWORKS SolidNetWork License Manager\licenses\sw_d.lic -l D:\SOLIDWORKS SolidNetWork License Manager\lmgrd.log -z -s
15:34:00 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  D:\SOLIDWORKS SolidNetWork License Manager\licenses\sw_d.lic
15:34:00 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
15:34:00 (lmgrd) Starting vendor daemons ...
15:34:00 (lmgrd) Starting vendor daemon at port 25834
15:34:00 (lmgrd) Using vendor daemon port 25834 specified in license file
15:34:00 (lmgrd) Started SW_D (pid 1928)
15:34:02 (SW_D) FlexNet Licensing version v11.13.1.4 build 179569 i86_n3
15:34:02 (SW_D) SLOG: Summary LOG statistics is enabled.
15:34:02 (SW_D) SLOG: FNPLS-INTERNAL-CKPT1
15:34:03 (SW_D) SLOG: VM Status: 1
15:34:03 (SW_D) SLOG: FNPLS-INTERNAL-CKPT2
15:34:04 (SW_D) Error: Feature cae_cosmosfloworkspe is untrusted
15:34:04 (SW_D) Error: Feature cae_cosmosfloworks_elec is untrusted
15:34:04 (SW_D) Error: Feature cae_cosmosfloworks_hvac is untrusted
15:34:04 (SW_D) Error: Feature cae_cwadvpro is untrusted
15:34:04 (SW_D) Error: Feature campro is untrusted
15:34:04 (SW_D) Error: Feature edrw is untrusted
15:34:04 (SW_D) Error: Feature elecpro is untrusted
15:34:04 (SW_D) Error: Feature plastics_advanced is untrusted
15:34:04 (SW_D) Error: Feature solidworks is untrusted
15:34:04 (SW_D) Error: Feature swmbd_std is untrusted
15:34:04 (SW_D) Error: Feature swofficepremium is untrusted
15:34:04 (SW_D) Error: Feature swpdmstd_cadeditor is untrusted
15:34:04 (SW_D) Error: Feature swsustainability is untrusted
15:34:04 (SW_D) Error: Feature visupro is untrusted
15:34:04 (SW_D) License server system started on oitlm9
15:34:04 (SW_D) No features to serve, exiting
15:34:04 (SW_D) EXITING DUE TO SIGNAL 27 Exit reason 4
15:34:05 (lmgrd) SW_D exited with status 27 (No features to serve)
15:34:05 (lmgrd) SW_D daemon found no features.  Please correct
15:34:05 (lmgrd) license file and re-start daemons.
15:34:05 (lmgrd)
15:34:05 (lmgrd) This may be due to the fact that you are using
15:34:05 (lmgrd) a different license file from the one you expect.
15:34:05 (lmgrd) Check to make sure that:
15:34:05 (lmgrd) D:\SOLIDWORKS SolidNetWork License Manager\licenses\sw_d.lic
15:34:05 (lmgrd) is the license file you want to use.
15:34:05 (lmgrd)
