part custom properties not showing correctly in drawings 2018 SP3
Question asked by Jim Steinmeyer on Jul 30, 2018
Latest reply on Jul 30, 2018 by Jim Steinmeyer
     We upgraded to  2018 SP3 at the end of last week and are now seeing problems with our drawings. A co-worker this morning had a drawing that showed the revision description in the revision letter location of the title blok. We went into the CPs and found that the revision CP had pulled in the incorrect block from the rev table.
     I just created a drawing where the weight showed correctly in the part but was vastly different in the title block. I attempted to edit the title block to call the correct property and while it showed corrected, it reverted to the incorrect value as soon as I checked ok.
     Has anyone else seen this behavior? Do I need to recreate my templates in 2018 to get around this? What a time killer if I do. Also, didn't the text box used to show the name of the property linked to when you selected it to edit? It was not showing for me.
