Re: Why exported part to DXF shows hidden lines as visible?
Kevin Pymm Jul 30, 2018 6:15 AM (in response to Habib Ghalamkari)-
Dennis Bacon Jul 30, 2018 7:16 AM (in response to Kevin Pymm)It looks like it has something to do with how you have your System Options "Default Template" for Drawings set.. Open the drawing Drawing template and check to see how you have the Display Style set. If I use this,,,
I get this. Edit:.. Ooops,, I see that is a System option so changing your drawing template should not have any effect on it. But by changing that system option you should get what you want.
If I have hidden lines visible I get what you show in your screenshot.
Probably would be a good idea to not to change the drawing template you want to use for your drawings if that is the way you like it.... So you can make another template with the corrected settings and use that as your default.
Habib Ghalamkari Jul 30, 2018 8:53 PM (in response to Dennis Bacon)Dennis, I simply don't know how to thank you.
Million thanks.
