I would like to add a die size for use in the Hole Wizard. I have to cut an external thread at M17x1.0. An earlier search directed me to adding threads via the System Options but so far I can't seem locate the newly created thread when I want to create the external thread on the part.
Can anyone of you shed some light on the situation that is described above?
Thank you for your responses in advance.
Yours sincerely,
Daan de Vos
LouwersHanique B.V.
The Netherlands
you can find the file location for the default threads under the system options/file locations. You can modify existing or creating new and save them to that location (or add a new one) just ensure the file type is saved as a library part (.SLDLPF) so it will show up as a selection option.
this video is also helpful if you are still confused:
https://www.youtube.com/watch?v=3cgYVJr7Ycc
