I would like to veiw all of my past forum history. Is this possible ?
Also, can a member store a bookmark file of his choosing in this forum ?
Hi Frank,
If you click on your little profile picture (just to the right of your inbox bell) near the top right corner of the screen you will see that if will then give you an option "Your Content". Click on that and it will list all of the threads that you have created. If that's what you wanted?
As for your second question, I'm not so sure I understand exactly what you mean. You can bookmark any thread you like, but can you give me more info on what exactly you meant?
Dave.
Q #1. Very good Dave ! I knew it was "Something" content but was looking in the wrong place.
Q2. I get these notification that (member x) has bookmarked your post. Does this mean outside the forum or inside ?
Q2. It means they've bookmarked it inside the forum Frank.
Keep in mind though that any thread can be converted to pdf and saved outside of the forum. This is actually a very handy feature. The exception seems to be once a thread reaches a certain large size (not sure what size that actually is) the view as pdf function disappears.
Dave.
It basically means just that!
It means that a member has bookmarked one of your particular threads and then that member can quickly re-find that thread at anytime just by looking for it in his/her list of bookmarks. Just like you may bookmark a page in book, the forum is the book and the threads are the pages............
Dave.
Yes. On any specific piece of content, look at the list of options on the right hand side near the top. You should see options like Follow, Share, Bookmark, Like. Just click on Bookmark. Then to get to your bookmarks go to the Actions pull down menu in the upper left and choose "My Bookmarks". There are other ways to navigate to your bookmarks too, like from your profile page.
I hope this helps,
Jim
Jim Wilkinson wrote:
Yes. On any specific piece of content, look at the list of options on the right hand side near the top. You should see options like Follow, Share, Bookmark, Like. Just click on Bookmark."
Jim, can you give me an example of the "Specific piece of content" that I would find this option ?
I'm not Jim, but I'll answer anyway. See below. Your options there will be different since you created this Discussion, but "Bookmark" should still be there.
Hi Frank,
Dave.
