1 Reply Latest reply on Aug 23, 2018 2:36 PM by Matthieu Fourcade
    Adding Multipliers to Various Attributes
    Jeff Whalen
      I have a few questions in regards to adding multipliers to various drawing attributes. I've had some difficulty getting the following to work and would be interested to know if there are solutions:
      1) Multipliers on Dimensions and Corresponding GD&T - When I link a GD&T control frame to a dimension that has a multiplier, the multiplier does not apply to the GD&T control frame; I have to also add a separate multiplier to the GD&T, which seems redundant. Is there any way to link these in a way that the GD&T follows the dimensions multiplier?
      2) Grouping of Dimensions and GD&T with Multipliers - When exporting multiplied dimensions and their corresponding GD&T to the inspection report, all the dimensions are grouped followed by the GD&T grouped, since they have different balloon numbers. However when dealing with a large multiplier (for example 25X), the dimensions and GD&T are separated by a large number of rows making it difficult to fill out the report. Is there anyway to interlace linked dimensions and GD&T Control Frames?
      3) Multipliers for Notes - Using the nX formatting that works to multiply dimensions doesn't seem to work with notes. Is there any way to multiply a note?
      4) Multipliers for Surface Finish - We have a need to call out surface finish around a repeating hole. Is there any way to add a multiplier to a surface finish callout so the drawing doesn't have so many separate callouts?
      Jeff
        • Re: Adding Multipliers to Various Attributes
          Matthieu Fourcade
          Hi Jeff,
          There are a couple things you can try.
          You can try to change the "quantity" in the inspection properties (as opposed to change the drawing) and then - if needed - create a row for each instance (right click on the characteristic in the tree).
          In 2019 we are also releasing more way to control the grouping / ungrouping etc. It should simply a lot of the problems you are bringing up.
          Regarding notes, I don't think you can change the quantity unfortunately.
          Best,
          Matt
