Can we create mold of this part - means core & cavity.
Ashok,
Just briefly looked into your part and one of the major issue is draft
Absolutely no draft on all places in draw direction (Yellow color shows-no draft)
This part will not release from the mold without proper draft and certain slots and pockets are formed by seal-off between core and cavity. These seal-off face need more angle.
Most of the outer profiles need either slide, lifter or both for undercut situations
Tim Taby,
Next time, look at the part...or at least the screen-shots of it. What you suggested...WILL...NOT...WORK.
Ashok Kumar wrote:
Sir thank you for your guidence, I tried but didn't get the results. Can you please share me the Solidworks final model.
A little freelance cash on the side for you JOHN,
Dave.
Ashok,
Here is the split into core, cavity and slides
I tried to minimize the number of slides and this will give you an idea.(there is an exploded view in the viewer)
Hope this helps
