1 Reply Latest reply on Jul 27, 2018 11:34 AM by Fifi Riri
    How can export the cartouches field with a macro
    Luca Maestrini
      Goodmorning,
      I want to export same cartouches fileds in a file, for example a txt, because i want to control these.
      In the cartouches there are many fields and I, in the drawing 2D, can see them in sheet format, cartouches filed. The text field are in a indented list that report the relative value like this:
      Can I export them in a file with a macro?
      Thank
        • Re: How can export the cartouches field with a macro
          Fifi Riri
          Hello, try this.
          It will create a text file in C:\
          Option Explicit
          Dim swView As SldWorks.View
          Dim swNote As SldWorks.Note
          Set swDraw = swApp.ActiveDoc
          Set swView = swDraw.GetFirstView
          Set swNote = swView.GetFirstNote
          Do While Not swNote Is Nothing
            Debug.Print swNote.GetName
            Debug.Print "  " & swNote.PropertyLinkedText
            'Debug.Print "  " & swNote.GetText
            Debug.Print
            WriteFile swNote.GetName & " :  " & swNote.PropertyLinkedText & vbCrLf
            Set swNote = swNote.GetNext
          Loop
          Sub WriteFile(logSTR As String)
            Dim My_filenumber As Integer
            My_filenumber = FreeFile
            Open "C:\MyNotes.txt" For Append As #My_filenumber
            Print #My_filenumber, logSTR
            Close #My_filenumber
          To export in a Excel file change those lines:
            WriteFile swNote.GetName & "," & swNote.PropertyLinkedText
            Open "C:\MyNotes.CSV" For Append As #My_filenumber
