I can use CreateTransformRotateAxis function to rotate a joint of the robot.(see the codes and video below)
However,it seems that the function just only rotate one component separately.
I want to rotate all joints at the same time.
How to rotate robot joints synchronously like the example in YouTube? (synchronous motion)
https://www.youtube.com/watch?v=6B8Iq9L2Eu4
【Code】
Private Sub MySub1()
Dim swModel As ModelDoc2
Dim swModelDocExt As ModelDocExtension
Dim swAssy As AssemblyDoc
Dim swDragOp As DragOperator
Dim swSelMgr As SelectionMgr
Dim swXform As MathTransform
Dim swMathUtil As MathUtility
Dim nPts(2) As Double
Dim bRet As Boolean
swModel = swApp.ActiveDoc
swAssy = swModel
swDragOp = swAssy.GetDragOperator
swSelMgr = swModel.SelectionManager
swMathUtil = swApp.GetMathUtility
swModelDocExt = swModel.Extension
Dim strRefPlaneName As String
Dim swRefPlane As RefPlane
Dim swRefPlaneTransform As MathTransform
'Get Reference Plane
strRefPlaneName = swFeature(0).Name
swRefPlane = swFeature(0).GetSpecificFeature2
swRefPlaneTransform = swRefPlane.Transform
'===[Origin Point]===
Dim aPointData(2) As Double
aPointData(0) = 0#
aPointData(1) = 0#
aPointData(2) = 0#
' Turn into a Variant
Dim vPointData As Object = aPointData
' Create a math point
Dim swOriginPoint As MathPoint
swOriginPoint = swMathUtil.CreatePoint(vPointData)
' Transform the reference plane origin from its canonical position to its actual position
Dim swOriginPointOnRefPlane As MathPoint
swOriginPointOnRefPlane =swOriginPoint.MultiplyTransform(swRefPlaneTransform)
' Get point data
vPointData = swOriginPointOnRefPlane.ArrayData
'===[Vector]===
Dim aVectorData(2) As Double
aVectorData(0) = 0#
aVectorData(1) = 0#
aVectorData(2) = 1.0#
Dim vVectorData As Object
vVectorData = aVectorData
Dim swNormalVector As MathVector
swNormalVector = swMathUtil.CreateVector(vVectorData)
Dim swNormalVectorRefPlane As MathVector
swNormalVectorRefPlane =swNormalVector.MultiplyTransform(swRefPlaneTransform)
vVectorData = swNormalVectorRefPlane.ArrayData
swDragOp.DynamicClearanceEnabled = False
swDragOp.TransformType = 1
swDragOp.DragMode = 1
bRet = swDragOp.AddComponent(swComp(0), False)
swXform = swMathUtil.CreateTransformRotateAxis(swOriginPointOnRefPlane, swNormalVectorRefPlane, 1 * RadPerDeg)
bRet = swDragOp.BeginDrag
Dim nNow As Single
For i = 0 To 44
bRet = swDragOp.DragAsUI(swXform)
nNow =Microsoft.VisualBasic.Timer
While Microsoft.VisualBasic.Timer < nNow +0.01
DoEvents()
End While
Next i
bRet = swDragOp.EndDrag
swModel.EditRebuild3()
swModel.ClearSelection2(True)
You need to use presentations transforms. Take a look at this example which transforms two components simultaneously: Load Components Presentation Transforms From CSV File
