Help with Changing component configuration within assembly with a macro?
Question asked by Josh Hixon on Jul 25, 2018
Latest reply on Jul 25, 2018 by Josh Hixon
My code for this macro seems like it should be right, but I can not for the life of me figure why I keep getting this error.
The code is intended to change a few different parts and subassembly configurations based on top level custom properties. I feel like it is not setting swcomp to anything even though it doesn't error. My first component name is the same as my top level assembly and changes per order.
Here is my code:
Dim swapp As SldWorks.SldWorks
Dim Swmodel As SldWorks.ModelDoc2
Dim swcomp As SldWorks.Component2
Dim swassy As SldWorks.AssemblyDoc
Dim RorX As String
Dim Color As String
Dim Stepsd As String
Dim stepsz As String
Dim frame As String
Dim Name As String
Dim sel As SldWorks.SelectionMgr
Dim status As Boolean
Set swapp = Application.SldWorks
Set Swmodel = swapp.ActiveDoc
If Swmodel Is Nothing Or (Swmodel.GetType <> swDocASSEMBLY) Then
    swapp.SendMsgToUser ("Open a Starting Block assembly and try again")
    Exit Sub
Set swassy = Swmodel
' define the custom property vaiables_____________________________________________________________________
RorX = Swmodel.CustomInfo("Block Type")
Color = Swmodel.CustomInfo("SB Color - Steel")
Stepsd = Swmodel.CustomInfo("SB Step Location")
stepsz = Swmodel.CustomInfo("SB Step Size")
frame = Swmodel.CustomInfo("SB Setback")
' File name for Frame________________________________________________________________________________________________________
Name = Mid(Swmodel.GetPathName, InStrRev(Swmodel.GetPathName, "\") + 1)
Name = Left(Name, InStrRev(Name, ".") - 1)
'Frame Handling_________________________________________________________________
Set swcomp = swassy.GetComponentByName(Name)
If CInt(frame) >= 24 Then
swcomp.ReferencedConfiguration = "SHORT"
Else
swcomp.ReferencedConfiguration = "LONG"
On a tangent, I see some people add awesome little-numbered lines when they post code on the forums... how do you do this?
