I'm trying to determine the flow rate of water through some complicated geometry and I'm getting the above warning. I've seen this before and managed to fix the issue. However in this case, the error does not seem applicable. I've set goals for inlet and outlet flow with only outlet used for convergence. These goals use the same surfaces which my pressure boundary conditions use. As I'm typing this:
Current Values
Inlet Flow = 10.8982
Outlet Flow = ( - ) 10.8995
Inlet / Outlet = .9999
Average Values
Inlet Flow = 10.9128
Outlet Flow = ( - ) 10.914
Yet the warning message states that the Inlet / Outlet = 0.235463. Not even close... What gives? Should this lower my confidence in the results?
the error message has no idea about your inlet and outlets. It is telling you that for the opening that the error refers to that the ratio of inlet (flow coming into the domain) to outlet (flow leaving the domain) is 25% or so.
