LCLuciano Capitomboli25/07/2018
Hi everyone
I'm facing some problem when trying to import from Solidwoks to Revit. The situation is as follows:
I have a file assembly of a mechanical equipment that i want to export into a Revit family.
Firstly I saved the ASSEMBLY file onto a new PART file.
Then I exported the assembly into ACIS using the .SAT version 7. To do so, I used tools/export to AEC.
After the defeaturing I saved the ACIS file.
I then imported this ACIS with Revit but all I see is some parts only of the geometry. And the elements are now binded into a single object.
Does anyone knows if there is a procedure or some setting to do in order to have the whole geometry imported and leave the elements indipendent separated?
THANK YOU
