Create Drawings vba to vb.net convertion
Question asked by Prabaharan Pichaiyan on Jul 23, 2018
Latest reply on Jul 24, 2018 by Prabaharan Pichaiyan
I have a macro to create drawings which is working fine with vba. I need to convert that to vb.net. But its not working properly. May I know what's wrong with the codes
VBA codes
  Dim swSheet As SldWorks.Sheet
  Dim swView As SldWorks.View
  Dim vSheetName, vModelName
  Dim i As Long
  Dim boolstatus As Boolean
  Dim lErrors  As Long
  Dim lWarnings As Long
  Set swDraw = swApp.ActiveDoc
  Set swModel = swDraw
  'Visit each sheet
  vSheetName = swDraw.GetSheetNames
  For i = 0 To UBound(vSheetName)
    'Activate and access
    swDraw.ActivateSheet vSheetName(i)
    Set swSheet = swDraw.Sheet(vSheetName(i))
    If swSheet.IsLoaded Then
      'Okay
    Else
      If MsgBox(vSheetName(i) & " is not loaded.", vbOKCancel + vbDefaultButton2) = vbCancel Then Exit Sub
    'Visit all views
    Set swView = swDraw.GetFirstView
    While Not swView Is Nothing
      Select Case swView.Type
        Case swDrawingViewTypes_e.swDrawingNamedView
          If IsEmpty(vModelName) Then
           vModelName = UserForm1.partfilepath
          Else
            'Set the model in this view
            swDraw.InsertModelInPredefinedView vModelName
          'Make the sketches visible
          swView.ResetSketchVisibility
      End Select
      Set swView = swView.GetNextView
    Wend
  Next
  'Back to first view
  swDraw.ActivateSheet vSheetName(0)
  'Force a rebuild!
  swModel.ForceRebuild3 True
  swModel.EditRebuild3
  'Save drawing to same location as model
    Dim swIsoView As SldWorks.View
    Dim strFilePath As String
    strFilePath = Replace(vModelName, "sldprt", "SLDPRT")
    strFilePath = Replace(strFilePath, "SLDPRT", "slddrw")
    Debug.Print strFilePath
    'swModel.Extension.SaveAs strFilePath, 0, 0, Nothing, Empty, Empty
    boolstatus = swModel.SaveAs3(strFilePath, 0, 2)
    swApp.QuitDoc swModel.GetTitle
VB.net Codes
Sub Creator()
        swApp = CreateObject("SldWorks.Application")
        Part = swApp.NewDocument(TextBox2.Text, 12, 0, 0)
        Dim swDrawing As DrawingDoc
        swDrawing = Part
        Dim swSheet As Sheet
        swSheet = swDrawing.GetCurrentSheet()
        Part = swApp.ActiveDoc
        Dim myModelView As Object
        myModelView = Part.ActiveView
        myModelView.FrameState = 1
        Part.ViewZoomtofit2()
        vSheetName = swDraw.GetCurrentSheet()
            swDraw.ActivateSheet(vSheetName(i))
                    Case 7
                        If IsNothing(vModelName) Then
                            vModelName = partfilepath
                            MsgBox(vModelName)
                        Else
                            swDraw.InsertModelInPredefinedView(vModelName)
                            MsgBox(vModelName)
                        swView.ResetSketchVisibility()
                End Select
            End While
        Next
        swDraw.ActivateSheet(vSheetName(0))
        swDraw.EditRebuild()
        strFilePath = Replace(vModelName, "sldprt", "slddrw")
        swModel.Extension.SaveAs(strFilePath, 0, 0, Nothing, vbEmpty, vbEmpty)
        swApp.QuitDoc(swModel.GetTitle)
And I suspect the below particular portion is something wrong in vb.net
Case 7
                            MsgBox(vModelName)
                        Else
                            MsgBox(vModelName)
If anybody figure-out wrong stuffs, that would be grateful to me.
