Question as above,
I'm currently having to go thru' a fairly large assembly done by somebody else that is full of weldments that all have this option turned.
It taking forever to rebuild assembly and drawings.
At bottom of screen it says it is updating cutlists' so I figure turning them off might solve problems. There is some incontext stuff but am pretty sure most of problem is the above.
Maybe a macro? or some small utility or some other trickery, that would acheive this?
Thanks in advance
Neville
I do recall making a similar macro, will try to find out. In the meantime time you can use the #TASK tool to batch disable the option on parts.
