I have some parts in the BOM that should not have numeric QTY (ex. epoxy, tape, etc..)
I found a solution on the forums:
1) Add "AR"="Yes" property to the part
2) Bom QTY column is driven by equation: IF(`AR`="Yes";"A/R"; 'QTY.' )
This works well but I would rather have a "AltQty" property and equation: IF(`AltQty`<>"";'AltQty'; 'QTY.' )
This way if AltQty is assigned "A/R", then "A/R" shows up in the BOM qty column. Or some other text is assigned to "AltQty"
If nothing is assigned or property doesn't exist, then regular QTY is pulled.
The results I get are:
Parts without "AltQty" get assigned correct QTY
Parts with "AltQty" have a blank cell, no text...
Thoughts?
Thank you,
Boris.
This works great but I can't save the equation in the template. Is there a bug or has this always been the case?
