Texture is getting flipped when I click fast or accurate render...
What is the reason behind this? How do I flip texture?
Dropbox - Ecograph T RSG35-1077-0.svpj
On the Texture, unlock the "locked aspect ratio" toggle button. Then NEGATE the U (set U Tile to -0.22) then re-lock the aspect ratio.
Preview will then be flipped, but renders in fast/accurate will be correct.
You are right. Thanks.
