Hi All,
I had this nice macro on Autodesk Inventor to convert each drawing view to DXF and assign the part file name along with drawing revision.
I was wondering if someone could help me to convert it for solidworks?
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oViews as DrawingViews
oViews = oDoc.ActiveSheet.DrawingViews
strDrawingPath = ThisDoc.Path
strInterPath = Left(strDrawingPath,Len(strDrawingPath)-21)
strDXFPath=strInterPath & "01 Issued Drawings" & "\DXF Files"
oFolder = strDXFPath
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
strInterPathRdrive = Mid(Left(strDrawingPath,Len(strDrawingPath)-21),22)
strDXFRdrivePath=strInterPathRdrive & "01 Issued Drawings" & "\DXF Files"
strDXFRdrivePath = "R:\Drafting and Drawing\Contracts\" & strDXFRdrivePath
If Not System.IO.Directory.Exists(strDXFRdrivePath) Then
System.IO.Directory.CreateDirectory(strDXFRdrivePath)
'MsgBox(strDXFPath)
'Determine the number of views
Dim intViews,intViewsCount As Integer
Dim strViews as String
'strViews=InputBox("How many base views are there?","iLogic Question", 0)
'If strViews="" Then strViews="0"
'intViews=CInt(strViews)
intViewsCount = oViews.Count
Dim oView As DrawingView
- oDoc.DrawingSettings.DeferUpdates="False"
For k = 1 To intViewsCount
- oViews.Item(k).Suppressed
Next k
For j = 1 To intViewsCount
'This portion of the rule gets the part file name from a view.
If oViews.Item(j).ParentView Is Nothing Then
strView = j
- oViews.Item(j).Suppressed
oView = oViews.Item(j)
strFileName = oView.ReferencedDocumentDescriptor.DisplayName
y=Len(strFileName)
strFileName = Left(strFileName,y-4)
strDXFName = strFileName & "-Rev" & iProperties.Value("Project", "Revision Number")
strDXFPathandName = strDXFPath & "\" &strDXFName
strDXFRdrivePathandName = strDXFRdrivePath & "\" &strDXFName
'For creating DXF files on local drive
folder = CreateObject("Scripting.FileSystemObject")
source = folder.getfolder(strDXFPath)
count = source.files.count
x=0
For Each file In source.files
If File.Name = strDXFName & ".dxf" Then
question1 = MessageBox.Show("The file "& File.Name &" already exists on Local Drive. Do you want to overwrite it?", "iLogic Question" ,MessageBoxButtons.YesNo ,MessageBoxIcon.Question)
x=1
If question1 = vbYes Then
ThisDoc.Document.SaveAs (strDXFPathandName & (".dxf") ,True)
Next
If x<>1 Then
ThisDoc.Document.SaveAs(strDXFPathandName & (".dxf") , True)
'This is for creating DXF files on the R drive
source = folder.getfolder(strDXFRdrivePath)
a=0
question2 = MessageBox.Show("The file" & File.Name &" already exists on R Drive. Do you want to overwrite it?", "iLogic Question" ,MessageBoxButtons.YesNo ,MessageBoxIcon.Question)
a=1
If question2 = vbYes Then
ThisDoc.Document.SaveAs (strDXFRdrivePathandName & (".dxf") ,True)
Next
If a<>1 Then
ThisDoc.Document.SaveAs(strDXFRdrivePathandName & (".dxf") , True)
- ThisDoc.Save
'MsgBox(strDXFPathandName) 'The message box displays the part file name
Next j
For a = 1 To intViewsCount
'strView = l
- oViews.Item(a).Suppressed
Next a
- oDoc.DrawingSettings.DeferUpdates="True"
Regards,
Salman
