Re: Linking part drawings to assembly drawings
S. Leacox Jul 11, 2018 4:08 PM (in response to Jeremy Kepley)I'm no pro, But I would be looking at two solutions.
1. Use the E-drawing format Solid Works offers.
2. Use 3D PDF's. It's a different format.
I have also heard of JT files being used for viewing in cases like this.
What you are asking for is not possible with standard PDF formats. Standard PDF's only contain 2D information.
Monster Jesse Jul 11, 2018 4:06 PM (in response to S. Leacox)I have used 3d odd's before depending on the other end it works great.
Jeremy Kepley Jul 11, 2018 4:11 PM (in response to S. Leacox)I'm not sure we're on the same page. I'm not looking to give them any 3D models. I am trying to link part drawings that are associated with a particular assembly to an assembly's PDF document without creating a copy of the original part drawing PDF.
Monster Jesse Jul 11, 2018 4:12 PM (in response to Jeremy Kepley)so your looking to link a part drawing to the complete assembly drawing. correct?
Monster Jesse Jul 11, 2018 4:05 PM (in response to Jeremy Kepley)ok I'm sorry i have no answer but this is a good question il have to follow until it is resolved. good work.
Jeremy Kepley Jul 11, 2018 4:11 PM (in response to Monster Jesse)Thanks!
Matt Peneguy Jul 11, 2018 4:17 PM (in response to Jeremy Kepley)I create assembly drawings with the parts on subsequent sheets in the same drawing file. Are your assemblies too big to do this? How many parts are in each of these assemblies?
Are you using SW Pro or Premium? If so, you can install PDM Standard and all your drawings as PDF can follow the files inside the Vault.
S. Leacox Jul 11, 2018 4:20 PM (in response to Matt Peneguy)Few questions Matt:
Follow = Link?
PDM = Product Document Management. Is the a built in Solid Works product?
Can PDF's link to DXF files?
Matt Peneguy Jul 11, 2018 4:38 PM (in response to S. Leacox)PDM is not "internal" to SW. It is an add-in that is available to you if you have SW Pro or Premium. You have to install the server component on a Windows Server and the client goes on the computer with SW.
Follow!=Link but when you create a drawing and "check in" to the server Vault it will be the latest version matching the SW drawing file that will then reside in the vault also. So, if anyone needs the latest version, they can go to the Vault and retrieve the PDF.
I do not know of a way of linking PDFs to DXF files.
Josh Brady Jul 11, 2018 4:49 PM (in response to Matt Peneguy)Matt Peneguy wrote:
Based on the part about "keeping multiple copies of drawings" I'd say that any given part may be used in multiple different assemblies. It would be undesirable to have drawing sheets in multiple different assembly drawing files.
If you have multiple different assemblies that use the same parts, somewhere you have to store the data of what parts go with what assembly. You can:
-Make the PDF include the assembly sheets and the part drawing sheets. You've already stated that this is undesirable (and I agree) because you are storing multiple copies of the same data.
-Store all your PDFs well-named and organized, then put hyperlinks in your assembly PDF that the user can click to open the part drawing. This is undesirable because if you ever move your file archive then you have to update the hyperlinks in a lot of documents.
-Store the information about what assemblies contain what parts somewhere else, such as a database. This is what PDM is pretty much for. Your VAR can tell you about PDM. SolidWorks has one, but many software vendors can supply PDM. The PDF still doesn't contain all the part drawings, but you use the PDM system interface to navigate among drawings. I don't know if the function is built-in to SolidWorks PDM, but I am pretty confident that custom programming could be done that would give you a button within the PDM system to sort of "export" all of the PDFs related to an assembly into a single multipage PDF file. Ideally each sheet of the multipage PDF is watermarked as "Reference" or "Uncontrolled copy" so that nobody stores them permanently or thinks they're official. The master copies of every drawing still reside within the PDM system
Matt Peneguy Jul 11, 2018 6:16 PM (in response to Josh Brady)I mistakenly opened a can of worms with that post... Those are very good points Josh. I sometimes forget and just think about my workflow, which does have it's downsides. But with our workflow we don't really reuse parts in other assemblies as much and export the entire assembly from project to project, if necessary. Yes, I know that's going to sound horrible to most people, but it works for us. Our projects generally last years and putting those project files into their own silo prevents inadvertent changes to those files.
This is a very complicated matter and I made some assumptions that I probably shouldn't have when I replied to S. Leacox. This is a workflow dependent matter and I agree about getting the VAR involved. Even with his/her description, it is hard to nail down what may work best for him/her. The VAR can web session in and assess the files and what can be done and how or if PDM will help.
Jeremy Kepley Jul 11, 2018 6:31 PM (in response to Josh Brady)That's a very thorough answer, thank you. I am sending an email off to my VAR now to set up a meeting with them.
Jeremy Kepley Jul 11, 2018 5:04 PM (in response to Matt Peneguy)There are a couple issues I have with creating part drawings in the same drawing as assemblies. Foremost, we use parts in multiple assemblies. We would need a method to keep track of every change we made to a part and where that part is used so that we could update multiple drawings. We make a wide variety of products and we are constantly making changes so we need to have a system that makes it decently easy to ensure that the most up-to-date drawings available on our server.
I haven't used PDM software before. This may be a good route. We have Solidworks standard but we've been looking for a good reason (besides the Toolbox) to upgrade.
S. Leacox Jul 11, 2018 5:31 PM (in response to Jeremy Kepley)I use assemblies with assembly driven sheet metal. The catch to working that way is that the assembly must be open when editing the drawings of the parts. The advantage is that the entire assembly and parts and drawings can be copied as a group with relations intact.
I use this for sheet metal box's that change in size, material, and gauge, but not in design. To work this way, some thought has to go into how the parts are designed so they work as intended when the thickness and size are edited.
