These are the top 20 most accessed SOLIDWORKS® Knowledge Base solutions during the second quarter of 2018. It is a good idea to review these solutions to determine if any of them apply for your business.
Rank | Solution ID | Question |
1 | S-00752 | Does the SolidNetWork License (SNL) support installations in different global territories? |
2 | S-00997 | Does SolidWorks place a limit on the number of Custom Properties a file can have? |
3 | S-011149 | How is a new sheet format created using the title block from an existing sheet format? |
4 | S-00883 | What coordinate system is used when creating a curve through XYZ points? |
5 | S-012578 | What is the function of the SOLIDWORKS PDM® Database Server service? |
6 | S-010601 | After saving as a copy an in-context part, the copy does not update according to the assembly. Why? |
7 | S-010332 | When archive server compression (.gz) is enabled on a source server, are files transferred compressed to the target servers when replicating the files in Enterprise PDM? |
8 | S-01078 | How can I export an IGES file with NURBS surfaces? |
9 | S-00613 | Will McAfee Anti-Virus corrupt SolidWorks files as it did in the past? |
10 | S-011065 | Is it possible to upgrade a single user that was installed off of an administrative image without updating from an administrative image? |
11 | S-01103 | When importing an IGES (.igs) part, what could prevent the user from changing the color of the part? |
12 | S-01099 | Is DXF/DWG translated using a ASCII or Binary decoding system? |
13 | S-010544 | How can a user search for current logged in users in SOLIDWORKS® PDM? |
14 | S-011037 | What are different types of adaptive techniques available in COSMOSWorks 2007 and what is the difference between them? |
15 | S-011019 | What are the recommendations for creating SOLIDWORKS® templates that will be used in SOLIDWORKS PDM? |
16 | S-00935 | A hole wizard can not be found a day after it was added. Are favorites deleted? |
17 | S-00780 | Is it necessary to shut down the SOLIDWORKS® software in order to release a license for a SOLIDWORKS add-in? |
18 | S-01067 | When I import a Parasolid, ACIS, STEP or IGES file, why do I not get any features? |
19 | S-00810 | How do I dimension to a "virtual sharp" (the theoretical intersection of two lines adjacent to where a fillet or other feature is added)? |
20 | S-01097 | When exporting a drawing 1:2, the DXF/DWG is at half scale. Why? |
