I am trying to modify a macro to complete a lengthy task on 3000 files. What I am trying to accomplish is to open a part or assembly( might use #task to batch)
set to diametric view, zoom to fit, set wire frame view, rotate part, force rebuild, then last is save as png.
I am getting a compile error right now with the codes I have put together.
I would appreciate any help getting this to work, I am definitely lacking training on API SW2017 sp5
Here are my codes
Option Explicit
Dim vConfNameArr As Variant
Dim sConfigName As String
Dim sPath As String
Dim i As Long
Dim bRebuild As Boolean
Dim bRet As Boolean
Sub Main()
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then
swApp.SendMsgToUser2 "Please open a PART file!", swMbWarning, swMbOk
Exit Sub
Set swModelView = swModel.ActiveView
Part.ShowNamedView2 "*Dimetric", 9
Part.ViewZoomtofit2
swModel.ViewDisplayWireframe
swModelView.RollBy (Degrees2Radians(-90)) ' Roll the model view by the specified angle
bRebuild = swModel.ForceRebuild3(False) 'Rebuild the current part
sPath = Left(swModel.GetPathName, InStrRev(swModel.GetPathName, "\")) 'Get the path
Next
this is the module for rotating parts
Function Degrees2Radians(ByVal DegVal As Double) As Double
Dim Pi As Double
Pi = 3.14159265359
Degrees2Radians = DegVal * 180 / Pi
You were missing a few declarations as well as the title of the file to save. I think I got it working the way you wanted with the code you provided.
