I am trying to utilize the sheet metal gauge tables because we have quite a few engineers and i like to make sure we are all using the same information. The problem i am running into is i have used the sample template provided by solidworks. Created the information i am using, but when i go to use it, solidworks tells me the bend table is invalid. I have attached the screen shot and the table. Any help would be appreciated.
That version of the Gauge tables are broken from my perspective. I was able to get it to work once, but it was not stable so I gave up on them. I ended up using the next step down gauge table that only allows a single K factor for the entire table. At least I was able to represent Radius and Thickness for one material per table in the next step down version.
Attached is my carbon steel table that does work.
