Hi all
I am having trouble with my stl file which contains at least 800000 faces which I would like to run on solidworks cfd.
I have tried completely all the possible method to try and convert it to solid body such as:
1)using meshlab where i managed to reduce it to 10000 faces where by when I open it on solidworks it can only convert to surface not solid.
2) try meshmixer and other software
3) try scan to 3d where i converted to a meshfile and still the mesh prep wizard doesnt even open.
I have spent months working on this and I am stuck at that very position since then would any solidwork genius have any idea how I can get this file to soid body can I can try and a cfd analysis
much appreiated.
Hello Harsh,.. I played with it... it seems to import fine with reduction ~10k.. other than the remaining bodies for the antennas (would need to connect)?
