I drill a 1/16" size hole in ANSI standard in 3d part, but i can only dimension the decimal format not the fraction format.
How to dimension the fraction format in my drawings like 1/16"(+0.0002,0)?
If you want to make this change for a single dimension then go to the Other tab on its Property Manager, check the box at top for "Override Units", and select "Fractions".
If you want to make this change for all dimensions in a Drawing then go to Tools > Options > Document Properties > Units and enter a value in the cell shown below (typically 16, although it could be 32, or whatever).
