I'm trying to setup 2016 Workgroup PDM and 2016 Solidworks on a single machine.
Did a clean install of both PDM and SW (SP 5.0)
Here are the symptoms:
- VaultAdmin works, I can open, add users, change settings.
- Soliworks Explorer works and shows "My Vault" location with my test project setup
- ViewSetup doesn't work!
- Can't see any servers
- If I do "Add -> Localhost, port 40000" I get an error "The socket was closed gracefully on the other end"
- Server log does show "Server is running. Request Port listening for connections on PORT: 40000. WORKER THREADS: 10"
- Within SolidWorks, PDM Client add-in runs but no prompt to login, and all of the PDM menus/buttons are grayed out
Any thoughts?
Hi Boris,
The Workgroup PDM system doesn't make use of "View Setup". I think you are referring to PDM Standard but that doesn't operate through port 40000 (and 20000 and 30000) like Workgroup PDM does. PDM Standard operates through ports 3030 and 1434 (since it is a named SQL instances). So, you may wish to check connectivity on these ports instead before running View Setup again.
