I try to create table using the SWx sample macro(Attached).
Its working fine for the first run. if I delete the created table and rerun the macro again, its getting a error
May I know what was the issue with these codes?
Each time you insert a table with InsertTableAnnotation2 it increment its name
So you get the error when you try to select it with SelectID2("General Table1"...
Try this:
Option Explicit
Dim swDrawing As SldWorks.DrawingDoc
Dim swTableAnnotation As SldWorks.TableAnnotation
Dim swGeneralTableFeature As SldWorks.GeneralTableFeature
Dim swSelectionMgr As SldWorks.SelectionMgr
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swFeature As SldWorks.Feature
Dim nbrTableAnnotations As Long
Dim tableAnnotations As Variant
Dim i As Long
Dim anchorAttached As Boolean
Dim anchorType As Long
Dim nbrColumns As Long
Dim nbrRows As Long
'Open drawing document
Set swModel = swApp.ActiveDoc
'Insert table annotation
Set swDrawing = swModel
Set swTableAnnotation = swDrawing.InsertTableAnnotation2(False, 2.75123456559767E-02, 0.132124518483965, 1, "", 2, 2)
If Not swTableAnnotation Is Nothing Then
swTableAnnotation.BorderLineWeight = 0
swTableAnnotation.GridLineWeight = 0
Set swGeneralTableFeature = swTableAnnotation.GeneralTableFeature
Set swFeature = swGeneralTableFeature.GetFeature
Debug.Print "General table feature name: " & swFeature.Name
'Get general table feature's annotation data
nbrTableAnnotations = swGeneralTableFeature.GetTableAnnotationCount
Debug.Print "Number of annotations = " & nbrTableAnnotations
tableAnnotations = swGeneralTableFeature.GetTableAnnotations
For i = 0 To (nbrTableAnnotations - 1)
Set swTableAnnotation = tableAnnotations(i)
anchorAttached = swTableAnnotation.Anchored
Debug.Print "Table anchored = " & anchorAttached
anchorType = swTableAnnotation.anchorType
Debug.Print "Anchor type = " & anchorType
nbrColumns = swTableAnnotation.ColumnCount
Debug.Print "Number of columns = " & nbrColumns
nbrRows = swTableAnnotation.RowCount
Debug.Print "Number of rows = " & nbrRows
Next i
Try this:
Option Explicit
Dim i As Long
Dim nbrRows As Long
Next i
