I often find myself fiddling around to select the origin when dimensioning sketches, does anyone know of a macro that selects the origin while I'm in the smart dimension?
I know that I can select the origin prior to starting smart dimension but that's still a bit awkward.
Br,
This macro will create a dimension between the user selection and the origin
Preconditions:
- a sketch must be opened
- an object (line, point, etc...) must be selected in the sketch
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
Set swSelMgr = Part.SelectionManager
Dim selObj As Object
Set selObj = swSelMgr.GetSelectedObject6(1, 0)
boolstatus = Part.Extension.SelectByID2("Point1@Origin", "EXTSKETCHPOINT", 0, 0, 0, True, 0, Nothing, 0)
' If you don't want to create the dimension automatically, remove the lines below
Dim UserPreference As Boolean
UserPreference = swApp.GetUserPreferenceToggle(swUserPreferenceToggle_e.swInputDimValOnCreate)
swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swInputDimValOnCreate, False
Dim myDisplayDim As Object
Set myDisplayDim = Part.AddDimension2(0, 0, 0)
swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swInputDimValOnCreate, UserPreference
