I would like for this option to be automatically checked as default when starting new Assembly Drawings:
How can this be accomplished?
Thank you!
-Iain
Iain Hendry
Open your Assembly template and make that change and save the template.
So I should open the assembly template, insert a dummy assembly, and then insert a BOM, make the change to the setting, then delete the BOM/dummy assembly, and save?
Yeah that is what I would do, if you can't change it otherwise
Hello, is this still working in 2018?
Because i always get the message: 'a document which references other documents may not be saved as a template'
I deleted the dummy view and dummy BOM but still this warning.
Any ideas?
Iain Hendry
