Hi guys. We are implementing a new system that involves Flow Drilling. If you're not familiar with Flow Drilling, it is a process in which the material is penetrated, melted slightly and pushed back to create more material for tapping (see youtube link below). For us, this process will replace weld nuts. Any ideas on how I can create a feature to represent this hole with the hole callout and make it so all of my coworkers can use the same feature?
Ok well either I didn't state my situation clearly or I've stumped the SW champions. Either way...I've figured it out! I made a simple boss with a tap through it and stuffed it in the design library. Now I can just drag and drop from the library and I get my hole callout and feature!
